In a moment of insanity, I bought a pair of in wall rear channel speakers - Klipsch RCW-5. Not that it is a bad speaker by any means. I bought it before I had decided to build a dedicated theater in the basement; when I was planning on putting it in the family room upstairs.
The basement is a different approach.... keep the sound inside the room. Doing so requires as little break in a continuous envelope as possible, and certainly you don't want to put a speaker in the midst of the sound barrier. The rest of the speakers I own are perfectly suitable (RF-5 left and right, RC-7 center, RS-35 surrounds and KSW-12 sub) but the in walls aren't going to cut it. My plan for the RCW-5s is to build enclosures and hang them at the rear of the room. Problem is, I am not sure about the construction of the enclosures. Any advice or guidance would be very much appreciated!
Jeff
Jeff
