JeffMckeon
- Mar 22, 2004
I'm building a new home and at the point where I'm going to begin my low voltage wiring.
My goal with my AV is to have nice system but not anything over the top. I have an office off of my living room where I'd like to keep all the AV equipment (reciever, dvd, cd player etc) and only have my speakers and TV visible in the living room.
To do this I need to run the AV wireing and speaker wiring in the walls/ceilings. The speaker stuff is no prob. The question I have is what is the best way to run the Component, Composit and S-Video cables through the walls so that in the office and living room I simply have wall jacks that have plugs for each type of cable.
The thought I had was to run RG6 quad sheilded coax and compression termintate it with F connectors on either end, then have a standard Femail-Femail F connector on a wall jack. For the S-Video I see several wall jacks available at partsexpress so that doesn't seem to be too big a deal. The composit cables I'm still not sure about.
Has anyone done this type of setup before and if so, can you suggest a way to proceed?
thanks,
Jeff
thanks,
Jeff
