Hi there, new member. Spent the last week or two reading thru the forums and learned a lot from the postings. I've attached the sketch of my design for my home theatre. This room is in the 3rd floor of a spec house being built. I need to complete the audio/data wiring this week, so any constructive feedback is much appreciated.
Some verbiage to go with the sketch:
* Room Dimensions: 20' x 11.5'
* Ceiling Height: 8'
* Speaker Config: 7.2 (probably initially a 7.1) (note: anywhere you see a picture of a "speaker" that denotes where I'll have audio pre-wired.
* Media cabinet in the back of the room (re-thinking that, likely to move to front)
* Planning 2 screens: Flat screen on left wall and then pull down (or electric) project screen from ceiling above left wall right in front of flat screen. (note: having conduit run from back of room (right wall) where media cabinet is to front (left) wall behind placement of flat screen for HDMI cable.
Questions:
1) This left wall where I show my flat screen / project screen is the right wall of the master bedroom on the floor below. Would I have less sound penetrating my master bedroom with the setup that I have now or would it be less if I flipped the room around and put screens (and front/center speakers) on right wall? In the former, the speakers are next to the master bedroom wall, but sound is travelling away from wall. In the latter, main speakers are 20' away from master bedroom wall, but sound is travelling toward the wall. Thoughts?
2) Any suggestions / thoughts on the set-up / wiring?
Thanks in advance, Stefan.
Questions:
