Could anyone reccomend a kit for Hometheater mains? It will be 90% Hometheater and 10% music. I am looking for Floor standing towers to be used with a Denon 3802 with a Klipsh RC-7 center.
If you're looking for something with efficiency to match the Klipsch speaker, you could try an Adire 10-12" coaxial... or some kind of line array. What kind of sound do you want?
If it were me I would check out the Adire KIT LLC and ask them about putting the woofers both below or above and below the TM. You could then later build a conventional LLC as a matching center. If you like your RC-7 Center and want to maintain that sort of sensitivity, I would check out the Adire HE10.1 or HE12.1.
