Todd K
- Oct 21, 2001
Hello all,
I'm running Windows XP, and whenever I connect to the Internet, my computer is set to check for Windows updates automatically. Well, a few days ago, one came down the pike, and I installed it. However, every day since then, when I connect, it says there's a new update to install, but it's the same one!
This is the update in question:
Security Update for Windows XP (KB835732)
Multiple security issues have been identified that could allow an attacker to compromise a computer running Windows and gain complete control over it. You can help protect your computer by installing this update from Microsoft. After you install this item, you may have to restart your computer.
Any idea what the problem is?
Todd
Todd
