craig carroll
- Oct 25, 2001
I have a kenwood htb 504 home theater system, had it 2 weeks now, its worked great...
this morning, i turned on a cd to listen to while gettin ready for work and whatnot, i went to leave, and i left the receiver on all day ~8hrs, i get home, turn the cd player back on, and nothing, no sound at any volume level, nothing when i try my tv either...
on the front of it, theres a 'diagram' of the speaker setup, showing the 5 speakers and the sub, and it tells you which ones are being used in what mode you select (i.e. stereo shows just front 2, full surround shows all)
now none of them are showing as on, did it just get too hot? anyone have an idea?
i dont think its the connections, because i didnt touch it, after i got no sound i did give each wire the infamous 'this'll fix it' wiggle
craig
craig
