Chuck C
- Jan 6, 2001
If you're looking to buy a Hi-def capable TV soon, take 10 minutes to read and learn Link Removed
Hint Hint...you might want a DVI input
CRT PJ, here I come
Hold up...you better hope it has a DVI input with HDCP protection unless you wanna scale 480p signals to a higher resoulution for the rest of your days.
