joethastud
- Nov 12, 2007
- Joe B.
I am trying to set up Digital sound while only having to use 1 optical cable. I have 3 HDMI inputs on the back of my television all being used - HD-DVD, satellite, and XBOX360. It was my understanding that with HDMI cables, all you need to do is connect them to your television and then use the Digital (fiber optic) out on the back and connect it to your receiver/amp. My receiver is a little bit older and doesn't have an HDMI input in the back. It's a Sony 7.1 90watt per channel. My television is a Samsung DLP 55" 720p. I get sound from all of the components, but the receiver is not recognizing it as digital 5.1. I can't find a setting on the TV's sound settings that has anything that switches it over to digital. And when I connect everything individually with a fiber optic cable directly to the receiver output 5.1 without a problem. I have my receiver set to fiber optic only too. So I get audio (PCM 48 I believe??), it's just not Dolby Digital 5.1, anyone know why my receiver wouldn't recognize that any of these are putting out digital 5.1 sound?
Sorry for the run-on sentences and thanks for any help!
A
A
