Ken Wagner
- Feb 21, 1999
Anyone have any experience with these. Brand, pricing, online sales? How accurate are they? Thanks.
This is WAAS enabled and is accurate down to a few feet.
This isn't possible with the hand helds...at least not with out some sort of correction factor being applied on the fly from a ground control station. Typically the range of accuracy depends partially on how you have your GPS set up but assuming you have the averaging function turned on you should be able to get within 15 - 20 feet or so of the true location the most of the time. Things like buildings, hills, trees, & low number of aquired satalites ets all lower the accuracy.
As for brands etc we tend to stick to Garmin's and have had great success with them. I would make sure that which ever one you buy has some sort of PC interface cable to allow you to update the software/firmware etc and allow you to connect it to a laptop etc
