FS: Sony SDP-E9ES Digital Surround Processor (1 Viewer)
Orin Dym
$180 shipped UPS ground insured. Payment by paypal.
Description
I just upgraded to a Sony TAE-9000ES so this unit is up for sale. I do not have the original box, but I will pack securely, double boxed. No functional or cosmetic defects.
Have the manual and remote.
* Dolby Digital (AC-3®) decoding
* Digital Dolby Pro Logic surround decoding
* Digital Cinema Sound system -a Sony exclusive that recreates the precise acoustics of real movie production dubbing stages at Sony Pictures Studios in Culver City, California; you'll hear movies the way the producers and directors heard them
* Digital Cinema Sound 3D processing overcomes limitations in rear speaker placement with Virtual Enhanced Surround, Virtual Rear Shift and Virtual Multi Rear effects
* 24-bit digital processing decodes the full dynamic range of Dolby Digital sound tracks; exceeds the processing capabilities of previous Dolby Digital decoders; uses 53rd-order x2 FIR filtering for superlative accuracy; performs 44 million digital calculations every second
* Speaker size setup with bass redirection compensates for inability of many rear speakers to handle the full 20 to 20,000 Hz frequency response of Dolby Digital surround channels; redirects surround bass to the front speakers or subwoofer; 16 possible settings for complete system flexibility
* Rear-channel stereo
* Six-channel test tone for system alignment
* Digital crossover control with five crossover frequencies for bass redirection
* Digital "i" volume control regulates current to achieve a full 20 bits of resolution at every volume level
* Digital balance control for superior accuracy
* Independent digital bass and treble controls for front, center and surround channels
* Full Feed Forward Digital Filters with 3-stage oversampling for reduced requantizing noise; filter uses 8x oversampling, 45-bit internal processing and 20-bit outputs
* Current Pulse Digital-to-Analog Converters use highly accurate current source for greater precision than voltage sources, greater immunity to power supply voltage fluctuations
* Ultra-Rigid Frame & Beam Construction reduces the spread of vibration inside the chassis for reduced microphonics in low-level stages, purer sound
* Anti-resonant insulator feet with off-center drilling to minimize the transmission of shelf-borne vibration
* Set-up Wizard steps you through the process of initial set-up; makes sophisticated adjustments easy
* 20-character dot matrix display for accurate, informative function readouts
* Motorized master volume control with indicator LED
* Three Optical Digital Inputs to accommodate DVD Players and other Dolby Digital sources
* Coaxial Digital Input for high-quality digital-to-digital connections
* Single Optical Digital Output for high-quality digital-to-digital connections
* Dolby Digital RF Input for Dolby Digital decoding with compatible Laserdisc players
* Analog Outputs: Front L/R, Center (2), Rear L/R, Subwoofer
* Bypass Inputs: Front L/R, Center, Rear L/R, Subwoofer. Allows hookup of existing surround processor or preamp.
