RolandL
Probably, but a lot of work needs to be done to make it presentable. Check this thread: http://www.hometheaterforum.com/community/posts/3400028/
Same master, so it probably does.Greg Kintz is the man. I'd have to check my blu-ray and see if it has all the vertical misalignment that the Dvd shows. That's pretty terrible. If I were in charge, all these discs would already be out, and Bob and Greg would be my go to team. Ah well.
For those interested, here's a pic of the Optimax III lens assembly, which sheds some light on why vertical misalignment may have been a baked-in problem.
FRIDAY THE 13TH 3D is, by far, the best film I saw filmed in over/under. I love it. Saw it, many times, when it was in theaters.
The problem with Optimax III is not so much vertical misalignment as vertical parallax, which is similar but not identical. With vertical parallax, any object at the vertical plane of convergence will have zero misalignment. From there, the misalignment gets more severe as objects get closer to the camera, and also as they recede into the far distance.
