Focal enclosure (1 Viewer)
Mark gas
Link Removed
I just bought those speakers above and plan on using them inside for awhile can anybody Suggest a sealed enclosure size? will winisd work even Thou they are 3way's?
Pete Mazz
They are 2-ways, not 3-ways. 90 Hz on the low end is kinda high for integration with a sub.
Other than that, I've never heard these drivers.
Pete
Ron D Core
This is a car audio setup, thus the high crossover for the midbass. As long as you have the T/S parameters, most programs should work fine. Just make a sealed box, maybe .75 cu.ft. and stuff it with dampening material, should work fine as a temporary setup I guess.
Cam S
haha, it's all in french, I don't speak french!
I wonder how much of a difference that crossover would make for home audio use since it was designed for car use?
Mark gas
I don't think the xover will make a difference. When I finish them I will post some pics and then my next project a Cerwin Vega Stroker in a 3 cube box with about 1200 watts :D . If you are ever come to Surrey you can come by and have a listen.
Ron D Core
Stroker in the house or car? I heard two Stroker 15's in an old ass celica with two 1100 Watt amps hit about 152dB. It was pretty sweet to stand next to it let alone sit in it. The box was about 6 cu. ft. with a vertical slot port between the two woofers which were front firing. Just thought I'd mention it even though it has nothing to do with home audio. It WAS a diy setup however.
TheThrillisgone
