Zach_F
- Feb 24, 2002
With extra money coming in from Uncle Sam I couldn't think of a better way to spend it than on some electronic equip, yes I did have to sacrifice half the refund to get a new bedroom set for the wife......Anyway I am looking into my first HT set up, jbl s310 fronts, S-Center, S26 rears, yamaha htr5460, already have(panasonic rp56,32" tv). I wasn't sure on s310 or s312 for the front my living room is not that large 13'X 16'? I will probally listen to music as much as watch movies through the system. My couch backs right up to the wall. I could pull the couch out a little and put the speakers on stands but they would be really close to listeners heads, or I could mount them on the side walls pointing directly at the listener. If I mount them on the side, first is that possible with the jbl s26 and second does it take away from the quality of surround sound? The speaker set-up~$750, receiver 350.00+ S.H. etronics.com would greatly appreciate advice and other opinions on comparable set-ups for that price range.Make sure I am buying the right combinations... I am also a little confused about what type of speaker wire I should buy, as far as gauge and quality? Thanks for the help!!
Zach
Zach
