Patrick Larkin
- May 8, 2001
Mac users may want to check out DVD Shelf at http://www.splitcube.com/
As it stands right now I would not pay any money for this software. It does do what it says, but all fields must be manually entered. (From VersionTracker.com)
I remember this now, DVD Shelf has been out for a while, but I went with ReaderWare after I saw the user reviews for DVD Shelf. Essentially, you have to do all the work yourself, and it does not export HTML. Pretty useless.
With ReaderWare, all you have to do is scan in the barcode, and it automatically fetches from the internet a cover scan, cast & crew info, track listings in the case of audio CDs, etc. You can also drag & drop an IMDB URL and ReaderWare automatically downloads all the info. Definitely worth the extra $30.
Ted
