Hello All:
I am just curious how the majority of people connect up their dvd player. Do most of you connect the dvd player to your receiver, and then the receiver to your tv? Or do most of you connect the dvd player straight to the tv?
I am pretty new at this, so I have no idea what the advantages/disadvantages are to either one of these setups (I know Bob's write-up does say that if you do dvd-to-receiver you can use one remote).
My current system is comprised of:
-Denon 2200 DVD Player
-Denon 3803 Receiver
-Toshiba 57H82 TV
Note: I would like to buy some high quality component cables from bettercables; Do i need to buy two component cables if I were to do Dvd-to-Receiver-to-TV?
-Toshiba 57H82 TV
