Dolby Digital and DTS mandatory for HD-DVD and blu-ray (1 Viewer)
AlbertA
I haven't seen this post on the forum here. But here you go..
http://www.dtsonline.com/company/pre...cID=1&yID=2004
http://www.dolby.com/about/news_even..._23.09.04.html
Summary:
Dolby Digital Plus(*) and MLP Lossless are mandatory for HD-DVD.
Dolby Digital and DTS are mandatory for Blu-ray.
Optionally DTS++(**) (DTS extensions) for both formats.
*Dolby Digital Plus is backwards compatible with Dolby Digital and offers more channel and higher bit-rates.
**DTS++ is the collection of all DTS extensions, such as higer data rates ( Rates greater than 1.5Mbps), higher sampling rates (like DTS 96/24), more channels (up to 7.1) , lossless capabitily and maybe others.
Mike_J_Potter
Do any current receivers support these formats? Just wondering if I should put off a receiver upgrade until then.
David Judah
I wouldn't put off a receiver purchase if you need one now, because it will still be awhile before the formats are on the market. I would suggest, however, that the receiver you purchase has multi-channel inputs(preferrably 8 channel), since I imagine the players will have built-in decoders.
DJ
Dan Hitchman
However, Blu-Ray can do uncompressed 6 channels-24/192 LPCM or 8 channels-24/96 LPCM. They allocated 27+ Megabits/sec just for audio.
I'm not at all convinced about DTS++ Lossless until I hear how it works. For instance, if you have more than 6 channels then do you wind up with matrixed duplicate channels on the "backwards compatible" core portion of the data that must be de-matrixed. That would be unacceptable to me.
Why Blu-Ray doesn't add MLP Lossless into the mix is beyond me. It's a proven performer with licensing channels in place that can do upwards of 16 channels or more with bit-for-bit precision.
Kato87
