David D. C.
- Dec 30, 2001
i am going to purchase a denon 2802 reciever which puts out
the amplifier channel power is as follows
front: 90 watts x 2 (8 ohms 20hz - 20khz, 0.05% thd)
center: 90 watts (8 ohms 20hz - 20khz, 0.05% thd)
surround: 90 watts x 2 (8 ohms 20hz - 20khz, 0.05% thd)
surround back: 90 watts (8 ohms 20hz - 20khz, 0.05% thd)
the speakers i have for my surround backs are sony ssm-b100h's the peak power handling is 100 watts at 8ohms.
the speakers i have for my fronts are sony SSM-b300h's the peak power handling is 140 watts at 8ohms. with recommended rms power at 120 watts.
the speakers i have for my surround's are sony SS-SR305's the peak power handling is 100 watts at 8ohms.
the speaker i have for my surround center is sony SS-CN305 the peak power handling is 120 watts at 8ohms .
First Question: If I add an amp, what power range should I look for on it?
Second Question: Do I even need to add an amp?
Third Question: Should I have better speakers if I decide to get an amp?
There's a section called specifications for power amplifier section that reads as follows:
rated output for the following;
135W x 2 (6ohms, 1khz, 0.7% thd)
135W (6ohms, 1khz, 0.7% thd)
Fourth Question: Is this the section that tells me what my max power would be with and amp, or is this the max output power if I had 6ohm speakers?
Fith Question: If I decide to keep my speakers as listed earlier, is the chance of blowing them if I add an amp? I'm afraid they might.
