Michael FF
- Mar 5, 2002
I would very much like to hear the pros/cons of a DLP vs CRT front projector.
...while a CRT projector will need it's CRT's alligned manually every 4 months.Sorry, but this is just plain wrong. There was a guy on AVS the other day stating that he hadn't made any adjustments to his projector for two years. With a well done initial mechanical set up you may have to touch up your convergence once or twice a year (I check mine monthly, but very rarely have to fix anything). Even if you do have to touch up your convergence every few months it can be done in less than 10 minutes.
I am in the CRT camp, digitals looks flat to me, I am sensitive to rainbows, I can't stand screen door, I like black blacks, etc.
There are some cons to CRT:
1. They do require a light controlled room, You do not want to set one up in a room with any significant amount ambient light (I wouldn't want to setup a digital in a room with ambient light either). The problem here is that CRT's aren't as bright as many of the digital units.
2. They are big and they are heavy. Mine tips the scales at over 180 pounds.
3. They do require an initial setup that is time consuming and intimidating to a new comer. When I first got my CRT I was scared to death of setting it up since I had read how hard they are to work with (I later learned that a lot of the people that are saying how hard they are to setup are the ones in the digital crowd, many who have never set one up). But you will need to do some homework and figure out what controls do what. The initial setup can take several hours. Some are fairly easy to set up (Sonys) while some are more difficult (NECs).
4. CRT's have no zoom lenses, so your throw distance is fixed.
5. They can burn in. While it is true that they can burn in, the likely hood of it happening is pretty low if you take certain precautions. Calibrate the set using Avia or a similar test disk (in other words don't run it in torch mode). I have left a static image of white text on black screen, which is probably the worst thing you can do, for about 4 or 5 hours (I passed out on my couch watching Lord of the Rings )and I had no hint of burn. Long extended video game sessions are probably not a good idea if the games have static images, but 2-3 hour stints will probably not be a problem. I watch network TV with station bugs all the time and they are not a problem.
6. You will probably need to budget a scaler or HTPC. While most digitals have one built in most CRTs do not (mine does actually).
7. If you should happen to have a problem with your CRT, you can't easily just take it down and ship it somewhere to get fixed. But there are many people/places that will work with you in diagnosing your problem, many of them will send out new boards for you to try so you don't have to send the whole projector. It should also be noted that these are professional grade machines and are built like tanks. But if a serious problem should occur it will be a pain in the ass.
8. Some CRTs are loud and will require a hush box, there are many that are quiet though.
Considering all of the above I wouldn't trade my G70 for any digital on the market today. The picture that I get out of it is breathtaking. I went and checked out a HD2 DLP a few weekends ago and was impressed with the picture, but in my opinion they still have a long way to go. I also paid considerably less for my projector than any of the HD2 units.
