- Aug 23, 1998
I am running into this more and more. Buy a new disc and the player refuses to load it, then after several attempts (5-20 tries) finally does and the disc plays fine. The next time I go to play the disc, same problem.
I have seen this on two discs in the Deadwood set, and most recently Criterion's Amarcord and The Leopard. I don't have a second player to try these in (Toshiba BD60 with latest firmware), but every other disc loads fine, if they had problems initially, they continue to have problems.
Should I be returning these discs, or is this a player problem?
