Anyone have the discreet on and off remote codes for the new Dish PVR 501? Or maybe even old Dish discreet on and off codes that may work for this.
Basil
Not to get into a grammar argument or anything, but it's discrete code and not discreet code.
From Remote Central:
What are discrete codes?
They are versions of toggle codes that only perform one function. For instance, a "POWER" button on a remote would be a toggle, in that when it is used the current power state is reversed. If your device is on, it turns off. If it's off, it turns on. A "discrete" code would be a signal that ONLY turns the device on. If it is already on it remains so. These are most often used to ensure your home theater components stay completely in sync for powering on and off and changing inputs.
Such specialized and otherwise hidden codes may also be available for direct access to other "toggled" or "rotating" functions such as television inputs, receiver soundfield settings and on-screen display modes.
http://darius.mobius-soft.com/~andrea/ht/
The D-I-S-C-R-E-T-E codes are just not avail or no-one has cracked the code so to speak??
You say tomato I say tomaato, you say potato I say poaato.........
Basil
Here are codes for One-For-All remotes by Universal Electronics:
One For All Remote Extended Function codes for
Dish Network Satellite -
775 (0775) SATELLITE RECEIVER
Original Grey-Button Remote Functions (used on newer remotes as well):
273 Right/Browse 657 Left/Theme
465 Down 593 Up
528 Select 336 Cancel
400 Guide 274 Info
563 Menu 305 Recall
720 View 594 Power
432 TV/Video 177 Record
240 0 658 1
370 2 466 3
531 4 243 5
339 6 403 7
627 8 723 9
Blue-Button Remote Additions:
178 Page Down 179 Page Up
110 * 206 #
142 System Info
DISH Model 6000 Additions:
176 Mode (SD/HD)
Platinum Remote Additions:
(PVR Extended Function Codes for DISH PVR501)
237 PTV Menu 236 Rew (Back)
172 Skip Ahead 076 FF (Forward)
204 Skip Back 177 Record
050 Play 238 Stop
014 Pause
All of these codes are available by learning from the original remotes, right Ken? Just wanted to be sure I wasn't missing something.
