rAInMo9
Grip
- Nov 29, 2007
- Yim
I was wondering if dipoles are a lot better than direct radiating surrounds for movies. Also, are dipoles more "forgiving" in placement? It would seem that since they produce a diffuse sound field, you could place them in less ideal locations and still get good surround sound, versus direct radiating speakers which would have to be placed in a specific spot to get good sound. I am asking this because the only place i can put surrounds is on a shelf on a sidewall around halfway the distance between my seating position and the TV. Thanks.
P.S. The speakers that I am considering are the SVS SBS-01 system and the Monitor Audio Bronze series. If dipoles are a lot better than direct radiating speakers, I will probably get the Montor Audio Bronze series, as the surrounds in it (Monitor Audio Bronze BFX) are dipoles, versus the SVS surrounds (SBS-01).
