World Wide Stereo
Martin Dew
HTF News Editor
United Kingdom
Martin Dew
In December of last year Denon announced the imminent arrival of a new entry-level 2.1 soundbar, the DHT-S216. The S216 forms part of an extended family of DHT- models with the S716H topping the list on performance but with a corresponding $899 price tag. With that said, the budget S216 is adorned with some nifty features including DTS Virtual:X and Bluetooth connectivity for playing your tunes.
Design and Features
The 3.4kg (7.5lb) DHT-S216 is a sleek and well-built unit with a matte black textured body, which can be mounted on a wall or directly on your TV shelf. A neat grille wraps over the front fascia beneath which lie two 1.75-inch forward-facing midrange drivers and another two 1-inch forward-facing tweeters at the outer extremes of the cabinet. A further two 3-inch subwoofer drivers for added bass response, meanwhile, point downwards. The bar measures 89cm in length and a mere 6cm (2.4 inches) in height, making it a perfect companion for placement under your 55- or...
Continue reading...
728x90
prexhobby
