Denon 1803 No Sound 1st time using (1 Viewer)
AudioDude
Kirk
I hooked up the speakers went through the motions on the remote and nothing. I know im missing something here. I have the PS3 optical going into the bottom optical/digital input. Don't know what else to do.
Al.Anderson
Al
It's not wrong, but sometimes the receiver assumes you're coming in as HDMI, so you have to go in and tell it you're using a different input. Although on other receivers there's just a button (remote and/or receiver) that says 'Optical' (sometimes it's a button that says 'Input' and rotates through the ports).
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Most AVR are defaulted to analog. Assume you used an audio input, say "CD".
That input, you have to go into "set up" and attach the optical to said input.
Every AVR works this way. Download the manual if you don't have it.
Nielmb
