Anthony Moore
- Jul 12, 2001
I was looking into this monitor:
http://accessories.us.dell.com/sna/p...tegory_id=4009
It says it has component inputs. Is it HD-ready? If I got my cable company's HD cable service and connected it to this monitor, will the picture be as good as an hd-ready television? A little worse?
Diagonal Size: 20.1"
Viewable Size: 20.1"
Display Type: Flat panel display/TFT active matrix - desktop
Depth: 9.67"
Height: With stand: 25" (fully extended in portrait mode), 18" (compressed/locked in landscape mode)
Weight: 18.72 lbs (with stand and head)
Width: 17.6"
Image Max H-View Angle: ± 88° (typical)
Image Max V-View Angle: ± 88° (typical)
Analog Video Format: Analog RGB
Analog Video Signal: 0.7 Volts ± 5%, 75 ohm input impedance
Cable(s) included: 1 x 15-pin D-Sub and 1 x 24-pin DVI-D cable
Color Support: Yes
Compliant Standards: ENERGY STAR®
Connectivity Technology: Cable
Digital Video Format: DVI-D TMDS
Dot Pitch: 0.255 mm pixel pitch
Enclosure Color: Midnight Gray
Factory Preset Resolution Modes: 720x400 @ 70.1 Hz, 640x480 @ 59.9 Hz, 640x480 @ 75 Hz, 800x600 @ 60.3 Hz, 800x600 @ 75 Hz, 1024x768 @ 60 Hz, 1024x768 @ 75 Hz, 1152x864 @ 75 Hz, 1280x1024 @ 60 Hz, 1280x1024 @ 75 Hz, 1600x1200 @ 60 Hz
Front Panel Controls: Input Select, OSD Menu and Select, Minus (-) and Plus (+), Brightness / Contrast, Auto Adjust, Power Button and Indicator
Image Brightness: 250 cd/m2 (typical)
Image Contrast Ratio: 400:1
Lamp Type: CCFL (6) edgelight system
Max Operating Temperature: 95°F
Max Resolution: Up to 1600x1200 Pixels
Max Sync Rate (V x H): 76 Hz x 80 kHz
Min Operating Temperature: 41°F
Port(s) Total ( Free ) / Connector Type: 1 x 15-pin D-sub, 1 x 24-pin Digital DVI-D, 1 x S-Video, 1 x Composite Video, 5 x USB (1 Upstream and 4 Downstream)
Power Consumption Operational: 90 W (max. with USB and Soundbar)
Power Consumption Operational ( Standby : Less than 3 W Avg. (Active-off mode)
Video Input: Analog RGB, Digital DVI-D TMDS, S-Video, Composite Video
Voltage Required: 90 to 264 VAC
Humidity Range Operating: 10% to 80% (non-condensing)
OSD Languages: English, Spanish, French, German, Japanese
Compatibility: PC
Depth: 9.67"
Width: 17.6"
Color Support: Yes
Compatibility: PC
