Nathan Bower
Grip
- Oct 30, 2000
First post for a while - but I have some questions, and Im sure you boys won't mind helping!
I'm considering using 2 of the proposed "adire uber 15" drivers in a LT configuration using a smallish box and having the drivers pointing in opposite directions in order that the drivers reaction forces will ahnialate each other. MRS style. I intend to fully investigate each component of the system (alignment, box construction, LT, XO, EQ) in order to build simply the best subwoofer per cuft ratio ever achived. This means competeing with the likes of the beast, and all those PR'd strike-15's out there.
Seeing as the driver specs are still unavailable I have been researching amplifier options. There are lots of of CE 2000 amplifiers floating around on ebay for about $500. I have several concerns however:
1/ subharmonic (rumble) filter. I know that the K2 has a rumble filter at 8hz. This is fine for me, but I dont want to get a CE series amp only to find that there is a high pass at 20 hertz.
2/ UK 240 volts. On the K2 you can simply switch between 110 and 220/240 volts and plug it into your mains. Does this apply to the CE amps? Looking at the diagram on crowns site seems to suggest that the amp should just plug straight in to 240... correct?
3/ Fan. Any subjective opinions on how obtrusive the fan on the CE is?
Lastly, what amps have you gents put your money on when needing about 1KW per chanel. I will wait and see if I need the something more powerful like the CE4000 but I will want to get close to the uber 15 driver's xmax if I am to achieve my goal. I just hope that sensitivity hasnt gone completely out of the window with these new driver designs!
