Daniel J Hauer
- Dec 5, 2003
Hello all!
First off, this is my first post and I'm excited to be delving into the world of HT. I am certainly not new to audio or electronics, but this is my first attempt at a HT system.
Due to school I will not get to building anything until next summer, I am trying to get some plans started.
Bear in mind that I do not have a huge budget for this venture.
The plans for all the speakers are basically the same. I am thinking of a D'Appolito 3/2 speaker geometry using Tang Band W4-657S mids. I have not fully decided of the tweeters yet, but I have found some sheilded soft dome tweeters on sale.
The specs are as follows:
Fs 1473Hz
Qms 1.54
Qes 2.00
Qts 0.87
The specs for the Tang Bands can be found on their website and the tweeters are on sale at Apex Jr. (I would provide direct links, but that seems prohibited.)
I plan to go ported and WinISD shows a good response with an internal volume of .4 cu ft utilizing a single rear-facing port 2.5" x 5" for a 69hz tuning frequency.
The system will be crossed over at 3khz (perhaps a bit higher) and my calculations show that a 4.5" driver spacing would be appropriate which seems to work out nicely.
I will have a subwoofer(s) in the system and have about 1950W @ 4 ohms for bass duty. I am undecided on the subs and plan on talking with Dan Wiggins about that issue.
The speakers will reside on steel speaker stands filled with sand. My planned reciever is a Denon 6.1 unit. (for upgradability)
Any opinions on the driver / enclosure selection or any other aspect of my ideas would be greatly appreciated.
Of course, expect many more questions as this project evolves.
Thanks for the help!
D Hauer
Fs 1473Hz
Qms 1.54
Qes 2.00
Qts 0.87
D Hauer
