Like, every computer and laptop with a CD-RW or DVD-RW or BD-RW drive sold the the past 15 years?CD Recorders - Any suggestions for a good dependable unit?
I'm not certain what you're referring to. I admit I haven't bought them in probably 15 years, but I see them available from Memorex, Maxell and Verbatim.These days it would be pointless for recording purposes, when there are no more reliable blank disc manufacturers.
OK. I do remember CMC being garbage, and Taiyo Yuden being the best. Like I said, I doubt I’ve burned a disc of any type in the last 15 years.The (formerly) best manufacturer of blank cd/dvd discs Taiyo Yuden / JVC, was sold to the worst manufacturer of blank discs back in late 2015.
The (formerly) middle-of-the-road manufacturer of blank cd/dvd discs Verbatim, was also sold to the worst manufacturer of blank discs back in mid 2019.
I never trusted anything manufactured by CMC Magnetics.
It does. I have no idea what the author of this thread is after. Which is why I suggested the Tascam.As has already been mentioned, these days, for most people, a computer based solution makes a lot more sense.
For all of that talk about some brands being good and others being worse than terrible ...
My understanding is decent DVD-R is still manufactured under the Verbatim AZO brand using the Mitsubishi manufacturing standards, unless there's been a change or discontinuation. Regardless CD-R doesn't automatically mirror the same reliability standards as DVD-R, though variance by manufacturer probably holds. Not the least of which is due to the differences between the discs. As a lower capacity disc, CD-R has wider gaps between data tracks and is less prone to burn errors as a result. If you can find Verbatim CD-R manufactured in Taiwan, you're probably fine (though I've read country of origin matters less these days for Verbatim CD-R).The (formerly) best manufacturer of blank cd/dvd discs Taiyo Yuden / JVC, was sold to the worst manufacturer of blank discs back in late 2015.
Perhaps I didn't make myself clear, (if that's the case, I apologize.). What I'm looking for is a good, CD recording "unit". (someone did mentioned "Tascam"... is that the only one available, these days?)
If it works the first time you play it after burning it, it’s probably going to outlive you.
... my collection of burned discs has actually been a lot more stable over twenty years than the pressed discs I’ve bought in that timeframe.
In general, how does a digital recorder work? What is the "principal' behind a recorder such as this? How then is a cd made from a recorder like this? (Please excuse my ignorance in matters such as these.)Like, every computer and laptop with a CD-RW or DVD-RW or BD-RW drive sold the the past 15 years?
Unless you've got some retro-niche application, recording audio and burning audio onto a disc is very old hat. Buy a digital recorder. Buy some recordable discs. Use the computer you've surely got to burn stuff to disc. The hardest part might be the authoring software. There used to loads of free and cheap stuff out, but I haven't looked at that for years.
