I am in the finishing stages of my room. I was wondering if there is any recommendations of carpet, paint. Also should the ceiling be painted. Any help is appreciated.
I painted my ceilings and wall in stead of having a blown (popcorn)ceiling I finished it smooth. THe walls are dark blue and carpet is a blue also and seating is black the baseboard is trimmed in white. It works for me and the dark walls reflect no light so i love it. Check out my gallery.
Darker is better. Gloss = Bad Semi-Gloss = Bad Eggshell or Satin = Okay Flat = Best, but harder to clean
My colors: Ceiling-Dark Grey Accoustic Foam Upper half of walls - A dark magenta, satin Divider between upper and lower half of walls - Purple accoustic foam Lower half of walls - Dark "plum", satin Trim - "Midnight purple" one shade away from black Carpet - Commercial black carpet with little neon geometric shapes and squigles in it.
A designer would tell you that you should probably consider the room as a whole before selecting any colors.
Flat latex is a given but you really need a handle on your furniture selectionfabric, curtain colors, and what your speaker cabinets do to compliment or detract from these.
If you have a significant other, this can get even more complicated because most women would not understand your need to paint the walls black or other variations of dark tones.
I would use the furniture as a guide to color selection for the rest of the applications of your room. That includes the speakers.
