Alex_P
- Nov 3, 2003
Using WinISD, I choose closed cabinet. The measurement comes out to be 20.9"W x 32.4"H x 13.1"D. I don't like the shape of the box. I want to make it like a perfect cube box. With a lil math calculation, for a perfect cube box the length of each size is approximately 20.8" (doing it by hand, perhaps I should use a calculator ).
Questions:
1. Will a perfect cube box has the same result as the retangular shape (assuming they have the same volume)?
2. I want the driver to fire downward. Does it matter if the driver fire front or down since it's a closed cabinet?
This sub is going to be 90% movies and 10% music. I want to get a flat response on SPL. I wanted to go with ported cabinet BUT the size of the cabinet is too big :frowning: So I decided to go w/ the closed cabinet. Can someone give me some inputs regarding my 2 questions above? Thanks a million...
Alex,
Questions:
Alex,
