BryanDO
- Mar 22, 2004
I finished building my Adire Shiva project a while back. I've had alot of time to play around with poisitioning and settings but it never sounds the way I want it to. Out of the sub I wanted a very smooth, controlled (tight), and defined bass. Instead I got a sub with peaks at all different frequencies, it's not smooth and can be plain harsh, shaking everything at one frequency and not audible another. My very first sub was a Velodyne CHT-8 and I really liked the sound of it, but it didn't go quite low enough or loud for my tastes. The sub is in a 3 cu ft ported enclosure tuned to 19 Hz. The amp is giving the sub 150 watts and has a 4db boost at 25hz. I wish I could defeat the boost but I can't. I cant afford another amp either. I would like to build and enclosure with the amp and Shiva that will net me the results I want. Is it possible? Can you guys give me some designs ideas for the box? Thanks everyone...
