Mike Kao
- Oct 31, 2000
Right now I have a pair of birewireable Infinity HPS 1.5's up in the front ( link ). Although not exactly high-end, I find them them to be quite adequate. My rears on the other hands are jokes, so I plan on moving the 1.5's to the back and upgrading the front. Floorstanding Towers are not an option, I only need accuracy above 80hz frequencies anyway. I'd like to keep it under $500 and if possible, have a set that matches well with my Infinities. This isn't absolutely necessary however, as I could always upgrade the rears in the future. Right now I'm looking at the Infinity IL-10's, does anyone have any experiences with these speakers? I'll probably be upgrading my Infinity CC-2 center as well, so I'd get the IL-25C or IL-36C if I go the all infinity route. If I do, you think is 36C is worth the extra costs? Any other shelf/center combo suggestions are welcomed and appreciated as well!
