TRINADS
- Apr 6, 2007
- Jimmy
I have been reading a lot of input on bass shakers, and it seems that they are definately worth the money.
I just purchased 2 Aura ast 1b-4 bass shakers (specs: impedance: 4 ohms RMS 50W, max 100W w/ both, frequency 20-80 hz), and 2 VWS-100 (made by dot2 SR) bass shakers (specs: imendence: 2ohms, RMS 40W, 80W w/ 2, max power 100W, 200W w/ both, frequency: 20-80hz), (currently on ebay), I have a 7.1 onkyo reciever as my main amp, and have an old JVC 5.1 DD reciever, which is 85Wx5, I believe as my secondary amp that will drive the bass shakers. How would i hook this up so that I can get 8ohms output? Will it be a problem hooking them up to the JVC reciever? basically, I think I would split the LFE from main reciever, into the DVD input of the JVC reciever, and from there, I don't know what I should do. I know that I would use the secondary amp in stereo/mono function, & use R/L channels as outputs, but will the difference in ohms from both products cause a problem? Can anyone give me a detailed explaination to hooking up the bass shakers? Any help would be appreciated. I am very new to the technobabble of the ohms, ect. DETAILED explanation would be greatly appreciated. Thanks for your time!!
