Atmos Receiver Choices/help (1 Viewer)
Mustangelite
Robert Fischbach
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Just double checking that you did all the possible troubleshooting before spending money...
Did you remove EVERYTHING (speakers and components) and try plugging in one speaker at a time? Reason: Shorted wire, speaker, or component.
Did you try to reset? Google the model number and 'reset' and there should be a way to do it.
Kcuster50
