MickBurke
Grip
- Oct 24, 2002
I'm looking at gettign a new monitor for my new home, and this one looks like a good option... Any opinions? Anything else I should consider at the same size/price point? Thanks Much.
Mick
Mick
We currently have an analog Phillips 60-inch set which is, in my humble opinion, a fabulous analog RPTV--nice aesthetics, solidly constructed, and has a picture for DVD to die for (OK, I like the TV).Angelo, you can be sure you're in the minority when it comes to the Philips brand......and I'm right there with you. I've had my Philips Magnavox 60" analog RPTV for a little over 4 years now and I'm still amazed by this set. The funny thing about it is when I shopped around I never even considered this brand but when I realized the picture was as good as any, and better than a lot of other analog RPTVs (based on less than ideal in store demoing, of course), while costing at least a couple of hundred dollars less in most cases, I decided to take a chance and I'm glad that I did. When I'm ready to upgrade to HDTV I'll definitely consider Philips again.
Vin
Have you played around in the service menu? Any good tweaks?Nope, just did Video Essentials on it and that's it. My set is obviously a little older than yours (1998)....mine doesn't have the pedestal type base, no component video (just composite and S-video) and only has single point convergence which I check periodically only to find that it doesn't need any adjustment.
I have mine set up in the basement so I'll probably not upgrade to HDTV until it dies (at which point I'll probably take a sawz-all to it to get it out) or unless we decide to sell the house, the set stays and I get a new one!
I look forward to hearing what you have to say about the Philips HDTV if you decide to get one.
Good luck,
Vin
