Best size-direct view (1 Viewer)
Adam Wolkoff
Greetings:
I'm putting together a system for my parents. They want a direct view TV and will be sitting 10 feet away or so, due to room constraints and preferences.
32 or 36 inch?
TIA
ASW
Andy L
I sit about 10-12' from a 36" direct view. For normal viewing that size is pretty good. For widescreen movies, it actually seems a bit small. I would definitely go with 36" if you have the room.
foster2292
