Why does the 2 channel amp have 4 sets of speaker wire outputs? What benefit do you get from running Speaker channel A to the top posts of your speakers and speaker channel B to the bottom posts? I hope I am writing this correctly?
The Speaker A and Speaker B terminals are generally used to switch between pairs of speakers that may be in different rooms.
If your speakers have two pairs of binding posts, they are "bi-ampable" - with one pair of posts feeding the highs and mids, and the other pair feeding the woofers. If you are going to bi-amp your speakers, you must remove the metal plates that connect the two black posts and the two red posts.
That being said, bi-amping your speakers using a single receiver or amplifier is a waste of time (not to mention speaker wire). You aren't gaining anything at all - since the receiver is still pulling the same amount of power from the wall.
Speaker A/B selection is NOT intended to be used for bi-amping a single pair of speakers (by keeping the selector at A+B). There is absolutely no reason for doing this as there is no benefit to be gained.
