DaViD Boulet
- Feb 24, 1999
Ok Ken,
so combining what you say in this and another thread...if I understand you correctly:
Tell me if that all checks ok!
- A DTS bitstream is mandatory on all HD DVD or Blu-ray discs (similar to the way PCM or DD is mandatory on DVD).
- First-gen Blu-ray and HD DVD players already have the chips necessary to decode lossless DTS and downconvert to "regular" DTS for output via coax to legacy audio receivers (which ought to sound as good or better than DTS on DVD since it's higher bit-rate...more like D-VHS). This means that disc producers only need to provide a single "best quality" DTS audio track on the disc which would be able to be listened to in some form even by those without decoders able to handle compressed lossless DTS.
- Some first-gen players will also take lossless DTS and convert to multi-channel PCM to output via HDMI which some current receivers will be able to handle (if they can't handle the DTS lossless bitstream directly but are HDMI enabled).
- What no first-gen players by either camp can do is downconvert lossless DD to "regular DD" because the specs and chips aren't all worked out...but that capability ought to appear on 2nds or 3rd generation players.
