ThomasL
- Mar 13, 2001
I've made a few posts lately with regard to surge protectors since I'm currently doing a full house evaluation of all the cheap power strips/surge suppressors we're using and looking to replace them with some better units. One of the things that got me going down this path was that I noticed that when the washing machine motor turned on, there was a little blip of electrical noise sometimes on our main tv. I am pretty sure they are not on the same circuit and I don't know if it occurs on all tvs or on all channels since it happens so fast that it's impossible to reproduce in any controlled manner. In other words, I'm not sure if its coming from the electrical power or from some interference being introduced into the cable line. Right now, I have no cable protection/filtering in place and I have the tv plugged into an APC SurgeArrest Personal $20 surge protector. My question is: will a better model, say the Panamax Max8Coax or Tripp-Lite ISOBAR6DBS help to clean up this interference (whether its either on the cable or electrical line)? Or am I being overly optimistic? My main concern is if there is interference then something is "dirtying" the lines and that can't be good over the long run. I am probably going to replace the surge strip we have anyhow with one of the above models but I just want to know if the new better one will make any difference with regard to problems such as this.
thanks,
--tom
thanks,
--tom
