Adammccl
- Jan 15, 2007
- Dallas Tatebayashi
Which speakers are better out of the two? The JBL HLS410 or the JBL Control 1Xtreme? I currently have both of them and I' am trying to decide which one to sell on E-bay. I will need to sell one of them but I don't know which I should sell. I need to save money to get better speakers but in the mean while I need to get the most I can and I sure don't need two pairs of speakers so please tell me which speakers is the best out of the two so I can sell one. Both are in good condition and sound like new.
Here are some specs on the JBL Control 1Xtreme.
CONTROL1XTREME
2-Way, 4-Inch (100mm), Personal-Size Monitor Loudspeaker
Small-footprint, personal-size monitor with rugged, molded enclosure brings the music anywhere it's needed, including the home or office.
Shielded components allow placement next to video monitors.
Optional wall-mount brackets available (WBC1).
MSRP: $199.99PR
SPECIFICATIONS
General
Recommended Power Amplifier Range 10 Watts – 80 Watts
Impedance 8 Ohms
Sensitivity (2.83V @ 1m) 89dB
Frequency Response 80Hz – 20kHz
High-Frequency Driver 1/2" Titanium-laminate dome, shielded
Low-Frequency Driver 4", Shielded
Dimensions
(H x W x D) 9" x 6-1/16" x 5-7/16"
(228mm x 155mm 139mm)
Weight 5.2 lb (2.4kg)
Here's some specs on the JBL HLS410.
HLS410
Video Shielding allows speakers to be safely placed near a TV without distorting your television's picture.
MSRP: $229.00PR
SPECIFICATIONS
First Manufactured 1998
Last Manufactured 1999
First MSRP $229.00
General
Sensitivity (2.83V @ 1m) 86
Impedance 8
4"
Midrange Driver N/A
High-Frequency Driver 10mm mounted in Constant Directivity Horn
Recommended Power Amplifier Range 15 - 100 watts
Dimensions (H x W x D) 10 x 5 1/2 x 6 1/8"
Frequency Response (±3dB) 75 - 20kHz
I want to know the general feedbacks of the two speakers. Example: Someone might say the JBL HLS410 is a better speaker since it uses a horn and it can have a lower crossover point to blend the music better and the woofers is better quality and materal then the Control 1Xtreme. By the way that part where I said having lower crossover point is true fact about the HLS410.
CONTROL1XTREME
MSRP: $199.99PR
SPECIFICATIONS
General
Impedance 8 Ohms
Dimensions
HLS410
MSRP: $229.00PR
SPECIFICATIONS
First MSRP $229.00
General
Impedance 8
4"
Midrange Driver N/A
