David Preston
- Mar 23, 2003
I was looking for a fan the other day but couldn't find a real small one so I am still looking. It would be mainly for receiver. Will it increase life and performance of the receiver?
Will it increase life and performance of the receiver?Generally speaking, excessive heat is the worst enemy of electronic components, although some gear does need to warm up in order to produce satisfying sound. Some receivers will go into the "Protect" mode(shut down) if the internal temperature is to high. This can happen if your equipment is in a closed cabinet or in a poorly ventilated area. Trying to drive low impedance speakers that the receiver is not rated for can also cause the receiver to run hot. Adding a small fan can help. Radio Shack, as well as computer/electronics shops should be able to set you up with a small fan to coool your equipment.
I have never even heard of a DC fan causing electronic interference of any kind, and I've seen and used some pretty hefty fans with computers and electronics. Is this something one should be concerned with?Depending on the quality, DC fans generate all kinds of electrical noise. If they're integrated into a receiver/amp (or computer for that matter), then I'm sure the designers have isolated them with noise filters. I know that in the computer field where I come from, fans were very often a cause of electromagnetic noise that needed to be filtered and contained.
-Steve
I have never even heard of a DC fan causing electronic interference of any kind, and I've seen and used some pretty hefty fans with computers and electronics.Some types of fans are less prone to noise than others, and it also depends on the specific application. When you are taling about audio amplifiers, the type of noise generated by an AC or DC fan is a very real concern. Having said that, there are a few manufacturers who directly incorporate fans in their receivers, such as some Harman Kardon and previous Pioneer models, so it can be done. These fans are designed into the system though, so any noise is either filtered out and/or the fan was chosen by design to have as little noise as possible.
120vac fans should not be too hard to come by, many PC fans meet this criteria.
