Seth_L
- Apr 5, 2002
I've seen a few things from Tom V. about the new SVS sub. Things like:
The unit will have user adjustable tuning(ala' PC+ for example). In maximum extension mode...it will extend down to the 6-9hz range in the typical room. In maximum output mode(tuned around 25hz)...it approaches 130dBs. Like all subs, as you tune it lower(increase extension) you'll trade off a bit of maximum output capabilities at each tuning step.
It will be a passive enclosure that we will package with a large amp and a parametric EQ(or you can purchase the subwoofer itself separately).Now I was milling over what I know of subs and low frequency reproduction and I honestly couldn't think of what they could be using to achieve those goals.
It sounds like it's ported (unless it has an adjustable LT). Now how can they get 130dB in room from 2m away with a ported box that can also extend into single digits?
Are we talking like 4 15" AV15 drivers in a large sealed box with a LT and 2400W or have Tom and the gang stumbled onto something special?
My Tumult design is pretty nutty, but anechoic on it only places it to 118dB in room across the spread and it runs out of steam in the low teens. I know that to create low frequencies you have to move air. The Tumult is the biggest and baddest 15" around, so they have to be using several 15's or something even bigger than a 15. I don't think it can be a horn because they can't play that low in any reasonable size enclosure.
Any ideas?
Seth
