Tom Moran
- Oct 9, 2002
The following list of equipment for my first home theater:
Mitsubishi 65" Platinum Plus RPTV- WS-65869, Denon 3803 Receiver, Pioneer DV47A DVD player, Definitive Technologies Speakers - BP2006TL Front, C/L/R 2002 Center, BPX surrounds and a ProSub 100TL Subwoofer.
This setup fits into my equipment budget of 10-12K.
My Home Theater will be one corner of my finished basement with a low ceiling (under 7') and a roughly 12' square area.
I've read a lot of reviews and auditioned all of the above equipment and it seems to suit my needs which I would define as follows:
I want a screen of at least 50" and don't see the need for a plasma display because I will be able to eliminate ambient light well and frankly I like the look of projection images on this TV and the pioneer Elite series the best of what I have seen. I have to rule out all of the Pioneers and all of the smaller Mitsubishi's though because the clearance on my basement stairs is only 45" and this is the only TV I have found that comes in two pieces and hence will fit down my stairs.
On the audio side I have chosen the Denon receiver mainly because I like the sound and build quality of their equipment in general, it supports 7.1 sound, multi-room configurations and it has ample power for a space of this size.
The Disc player was chosen because it supports all formats, including SACD and it seems to be able to handle audio CD better than some of the lower end players. I want to be able to enjoy both DVD Audio and SACD titles even though the bulk of my listening will be standard 2 channel audio and movies.
I've chosen the Definitive Technologies speakers mainly for their rich sound quality and their amazingly wide sound stage. I'm hoping they will do a good job of creating an enveloping sound within my environment where traditional speakers would be likely to create a pretty small sweet spot due to limited options for speaker placement of the surround speakers. I especially like the integrated sub-woofers in the front stereo pair because I'd like to listen to my audio discs without the stand alone subwoofer turned on when I want to keep the levels low and/or stay true to the way the artists and engineers intended for the recording to be listened to.
So any advice you would like to offer would be welcome. I'm especially interested in hearing from owners of any of this equipment or those with ideas for other items that might be better choices while still fitting my budget and general needs.
Thanks in advance,
Tom
Thanks in advance,
Tom
