BrianFS
- Apr 7, 2002
Do optical inputs give you higher quality sound? I heard optical is warm and coaxial is sharp, but I don't know what that means to my ears. Can someone explain the differences in layman's terms? :b
i heard that when you plug an optical cable its your receiver that would decode the signal(dts or pro logik)
but whit the coax cable your signal would be transfered decoded.So you choose your cable in function
Uhhhh I dont think this is true.
My understanding is:
- If you load a DVD into your DVD player, both the optical and coaxial transmit the Dolby Digital bit stream.
- If you load a music CD into your DVD player, both the optical and coaxial transmit a PCM bit stream.
Most receivers have a "auto-sense" feature that tells the difference.
If you hook up the ANALOG L/R outputs from your DVD player, the DVD player is doing the decoding. Could this be what you are thinking of?
to make the dvd player decode the signal i know that u can
use the multi chanel out
is there a dvd player that can decode the dolby or dts and that does not have any multi chanel output?
if not i may be wrong but ill check whit my friend if i missunderstood something and ill come back tomorow
The job of the decoder is to take in the single digital bit-stream and output 6 channels of analog.
Generally, it is always better to let the receiver do the decoding. It usually has better chips and this allows the decoding & amplification to happen in the same box.
There is also the issues of time delays, bass management, etc, that the receiver can do while the signal is still digital.
