Neil_S
- Dec 2, 2000
For a new HT layout I'm planning on placing my equipment across the room from the TV. This will mean a run of about 15' for my video cables and I need to run them under the house and then up the wall. I'm planning on making my own (probably Belden 1694a) but here is my question...
It makes sense that you want to keep the number of 'patches' in your cable to a minimum... Ideally zero. If I were to use wall plates that would introduce two 'patches' to the cables. For example, a small component cables goes from the DVD player to the wall plate. This then patches it to the line under the house. On the TV side the same things happens. TV to wall plate which patches it to the line under the house. Essentially I would have three separate component sets hooked together at the wall plates.
What do others here with this similar issue do? Do you just run enough cable to leave a few feet dangling out of the wall on each side and not even bother with wall plates?
Can anyone understand my rambling? :b
Neil
Neil
