Troy LaMont
- Mar 11, 1999
I'm still doing my search for a sub and I've pretty much decided on an SVS. But, I just recently came across a great deal for a SPL 1200 that seems too good to pass up.
This is the output comparison between the two;
20-39cs - 109.5 / 20hz~91dB / 25hz~105.8dB
VELODYNE SPL12 - 107.1 / 20hz ~90 /25hz ~ 99
Specs;
Specifications:
Dimensions
inches (H x W x D)
14.5"W
X 14.75"H X 15.75"D
Finish
(Real Wood book matched Veneer)
Sealed
enclosure with Black woodgrain vinyl
Drivers
12"
forward firing, EPDM Variable Thickness Surround, Multi-Layer
Resin Cone,
3" dual-layer voice, and a Die-cast aluminum basket
Amplifier
1500
watts Dynamic, 750 watts RMS Power, Patented "ERS"
Amp
Low
Pass Crossover
40Hz-120Hz
Frequency
Response
22-120Hz
Inputs
Gold-plated
RCA line and speaker level inputs
Phase
control
or 180 degrees
Special
Features
Dynamic
Driver Control, Subwoofer Direct, Anti-clipping & Video
Shielded.
There would be a cost difference of about $250.
Any input would be much appreciated.
Thanks.
Troy
Specs;
Specifications:
Dimensions
inches (H x W x D)
14.5"W
X 14.75"H X 15.75"D
Finish
Sealed
Drivers
12"
Resin Cone,
Amplifier
1500
Amp
Low
Pass Crossover
40Hz-120Hz
Frequency
Response
22-120Hz
Inputs
Gold-plated
Phase
control
or 180 degrees
Special
Features
Dynamic
Shielded.
Thanks.
Troy
