Bill Mullin
- Jul 15, 1999
I've had a 50H81 for a couple of years and have been doing a 56-point convergence on it every 4 months or so. About a month ago I got a 65HX83, and now that it's well past its break-in, I decided to do the 56-point on this set. Things went pretty well, with 2 exceptions:
- When setting the overscan on the 50H81, I used the HPOS parameter to shift the display horizontally. I could not find the HPOS on the new set, nor could I find any paramter that would give me a horizontal shift. What do I use now?
- The key on the remote did not turn the blue grid on and off. Fortunately I still have my 50H81, so tested the remote and found that the 50H81's key worked fine on the 65HX81. But what key on the new remote to I use to turn on/off the blue grid?
Maybe all I need is a link with information to help me resolve these 2 problems??
One thing I've never really figured out with either set . . . I use Avia to set my overscan, but should this be done before or after doing the 56-point? I've tried both and not been 100% satisfied either way.
Thanks, Bill
Thanks, Bill
