John*Wells
- Jun 12, 2005
- John
I am considering upgrading to this model from my 4K UHD model I purchased in 2020. Is QLED really worth the extra cost?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Do you know how it was typically filmed, and if the 16:9 is a combination of cropping and open matte?
That is a Roku-branded TV, not a TCL. Looks like TCL has abandoned Roku for now, likely because Roku has decided to now make their own TVs. And that Roku is only 60Hz.In the TCL 5 Series? Probably not. However, you might as well go with THIS 6 Series for the same price.
Keep in mind, the 6 Series doesn't appear to be Roku, which is actually a plus for me.
I think John is trying to stay under $400.In addition to the aforementioned TCL, I’d also consider the Hisense U7K.
Todd is right. That was my initial thought. But I actually went up in my price point to this.I think John is trying to stay under $400.
Which is why I often get a separate vesa stand. $40 or so usually gets you there, depending on the size of the TV.Todd is right. That was my initial thought. But I actually went up in my price point to this.
https://www.bestbuy.com/site/samsun...4k-uhd-smart-tizen-tv/6537339.p?skuId=6537339
My reasoning had to do with the type of stand it came with. I don’t really care for the Roku stand feet and this Samsung works better for my small space. In doing that I gave up on getting the RCA jacks built in. But I have an old flat screen that has those for plug and play games
It's not super cheap, but if you ever want to upgrade your new tv purchase in order to play these on it down the road (such as if your old flat screen dies), this is a quality option at a lowish price point to upscale those and output them via HDMI to your new television.In doing that I gave up on getting the RCA jacks built in. But I have an old flat screen that has those for plug and play games
The Hisense U7K that I purchased a few weeks ago for our SC condo is the same way, and it uses Android TV. While I did connect the CATV (we get it as part of our HOA), I have just been using YouTube TV to watch live television on the display - - we subscribe to that service instead of cable TV for our Michigan home. I also connected a Roku Ultra 4K streaming box (already had it for the previous Vizio TV, which died) to the display, as I like that much better than Android TV.I should explain my objection to Roku TVs. I still use an antenna sometimes, and unless something has changed, Roku TVs have no direct channel access. In other words, you can't just enter "4 > Enter" to go to channel 4. You have to go to the channel guide and scroll through it to change channels, which kind of sucks if you're going from channel 4 to channel 31. I can't really speak to the streaming differences though.
I suspect they also have some Florida oceanfront property available.New TV showed up this morning. Samsung Qled. Forgive my ignorance but it says the speakers support Dolby atmos. In terms of Surround sound, what does that mean exactly?
Nothing. Dolby has really screwed up the marketing approach when it comes to Dolby Atmos.New TV showed up this morning. Samsung Qled. Forgive my ignorance but it says the speakers support Dolby atmos. In terms of Surround sound, what does that mean exactly?
Or, it has some form of "simulated" Atmos surround capability. But with tiny, tinny TV speakers, don't expect much.The serious answer is, it simply means that it will accept an Atmos digital stream, and pretend like it's actually reproducing anything resembling Atmos. Which it isn't. It should mean that it will actually reproduce sounds that are supposed to come from overhead, rather than just ignoring them.
So yeah, it's mostly marketing...
