Bjorn Olav Nyberg
- Oct 12, 1999
I have a Panasonic Tau Widescreen TV as well. It doesn't have Picture In Picture like the TV you linked to David, it is a smaller older model, but it is a regular TV technology.
Your english/american expression don't mean a thing to me, but I guess it would be a tube. With Clue, the norwegian expressions billedrør and bilderør, which means exactly the same thing in my book is translated as "s. (TV) kinescope, picture tube" and "cathode ray tube (CRT) [edb] display tube" respectively.
Anyway, the point is my Panasonic 32" TAU (Can't remember the model either) uses black bars on the side in 4:3 mode, and I can not see any form of burned in images at all. I have seen burn in on old computer screens so I have a fair image of what it would look like. Posts on HTF actually had me worried about getting a WS set as well, but in the end I figured a WS set was the way to go anyway, as anamorphic DVD's was what I was watching the most anyway. For regular 4:3 image I do not think this is a big compromise at all, my 32" TV still provide a bigger 4:3 frame than any other 4:3 TV me or my family have ever owned. The letdown is letterboxed nonanamorphic widescreen material, but I use the zoom function for this. I lose a little bit of info on the sides, and for 1.85:1 I even lose a little bit on top and bottom (about a centimeter). I could theoretically fix the latter with a kind of manual horisontal squeeze, which do not alter the picture very much in a way that I notice it, but since I can not do the same for the vertical, I leave it alone and just zoom in. This still provide acceptable results even on TV broadcast.
I don't know about anamorphic 4:3 but some DVDs with 4:3 supplements send some sort of flag that tells my TV to automatically drop into 4:3 mode. I'd guess this must be an authoring package issue but apparently if you have RGB connections to your TV it will automatically make these adjustments for you.
On my TV, and I think most WS TV's, it is the other way around. Anamorphic DVD's send a signal to switch to width mode (Can't remember the exact english term as I have switched to Norwegian expressions in the menu) when an anamorphic DVD is inserted, then switch back to the last modus you used when you are playing nonanamorphic material such as extras often is (Except for Anchor bay ) But anyway, because of this mixing anamorphic and nonanamorphic material is not a big issue for me.
Rambled on a bit there with stuff most of you will find uninteresting I guess, but I felt like addressing some of the concerns I had after reading about burn in on HTF for half a year before buying a WS set myself.
