I am intereszted in knowing where you get the professional test/setup discs you use to set up your HT systems. I want to get one for when I purchase my new DVD player so I can make sure I have everything set up properly.
There is a Sound & Vision HT setup disc, which they say is better for newbies. Then there's the DVE (Digital Video Essentials) disc, which is more for the intermediate user. These two are the cheaper ones. Then there's the Avia disc, which is for the experienced user. You can get the S&V disc thru their site (I think) at www.soundandvisionmag.com On the main page, at bottom left, there's a link to the disc. I think www.amazon.com has the DVE disc. Not sure about the Avia. Good luck!
Avia and DVE are very comparable. Avia is not for "advanced" users. It's oriented towards beginners and average users, but it, like DVE, also contains test patterns that can be used by advanced users as well.
Avia Pro, on the other hand is several hundred dollars, several DVDs, and is geared towards the Professional world. You want the regular Avia, or DVE most likely.
I have just posted a similar question in the forum. My components are a Samsung HTSK5 and A Toshiba HDX 52" projection TV. What should I expct to gain from using this CD?
