Leon O
- Feb 2, 2002
I suspect that I'll be purchasing 12 gauge Sound King speaker wire for my surrounds (unless anyone can talk me into alternatives). It seems to be about the best bang for the buck...
At the receiver end (Marantz SR7200) I'd like to use banana plugs. For the speaker end, I'd like to use pins. Target price range $3.00 - $5.00 per termination pair. Besides quality sound, I'd like something fairly rugged and attraction.
QUESTIONS:
- Do you have specific recomendations that would work well with the Sound King wire?
- What size/type Heat Shrink Tubing would you use as finishing touch?
Leon
QUESTIONS:
Leon
